Yanmar 3GM30F heavy smoke at high RPM
All,
Sorry if this has been posted before. However I wanted to share with you a recent experience that I had with my Yanmar 3GM30F. Anytime I would try to go over 2600 RPM I would blow heavy smoke. After many hours and many dollars, I discovered the issue was caused by the mechanical fuel lifter pump. It seems to be a common problem with these pumps. The problem is when the diaphragm becomes compromised and the engine oil is at full capacity, oil is is allowed to migrate into the fuel system. Once I changed the pump it resolved the issue. It should be noted that the pump I replaced was new out of the box.
That is definitely worth noting. Not something that I would have connected.
Thank you for posting.
Note that the smoke produced by burning engine oil has a blue tinge while smoke produced by an overloaded diesel engine is black. White “smoke” is actually either unburned diesel fuel or coolant vapor, the difference is the smell. Knowing these differences can help with the troubleshooting.
I am getting heavy white smoke on start up. Once running it goes away. I have no problems starting the engine. I had a mechanic replace the head gasket and clean the injectors. I replaced the elbow and installed a new lift pump. Any thoughts?
Keep the glow plugs engaged longer and drop warmup speed.
We ALWAYS had copious white smoke on startup. No other time. Idle would be rough. Kept rocker switch depressed longer and cured both symptoms. Could reduce throttle to at or near straight up (neutral idle speed) and reduced smoke dramatically.
Your mileage/smoke may vary.
G’luck.
Engine is a Perkins M30, three cylinder ~27hp
