Yanmar coolant expansion tank
I recently had to replace the leaking coolant overflow tank on my
2GM20F. The tank is made of polypropylene and almost no glue would
seal the crack that had developed. I checked the price of a Yanmar
replacement and was outraged to discover it was $76. (I don’t know
why this surprised me so much; I had to pay $175 for a warning buzzer
for the Yanmar panel.) I simply refused to pay that and went looking
on eBay for an automotive tank that seemed about the right size.
Tanks for cars run from $10 to about $25 and there is no magic in the
shape, other than fitting in the alloted space. I ordered what seemed
a reasonable replacement for $20 and when it arrived you can imagine
my surprise to discover that it was an exact, drop in replacement. I
didn’t even need to change the mounting bracket. The seller is still
advertising them on eBay, though without mentioning that it fits the
2GM20F engine. I just wanted to share this beat-the-Yanmar-system
link with the group:
http://cgi.ebay.com/ebaymotors/Yanmar-3JH-4JH-Coolant-Recovery-Overflow-Tank-Aut\
o-Too_W0QQitemZ320085380407QQihZ011QQcategoryZ124104QQrdZ1QQcmdZViewItem
Al Lorman
F30 Ab Initio
Al,
Make sure you use a pressure cap with the same opening pressure
setting as the original. Or use the original cap, if it fits. You
might risk your hoses.
— In freedomyachts2003@yahoogroups.com, “ajlorman” <ajlorman@…>
buzzer
looking
seemed
imagine
I
still
Overflow-Tank-Auto-
m
Al Lorman
F30 Ab Initio
Michel:
The pressure cap is, if I understand it correctly, mounted on the engine, not the expansion tank. I have a regulation Yanmar cap on the engine.
Al
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of michel.capelSent: Monday, February 26, 2007 10:18 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Yanmar coolant expansion tank
Al,Make sure you use a pressure cap with the same opening pressure setting as the original. Or use the original cap, if it fits. You might risk your hoses.Michel— In freedomyachts2003@yahoogroups.com, “ajlorman” <ajlorman@…> wrote:>> I recently had to replace the leaking coolant overflow tank on my> 2GM20F. The tank is made of polypropylene and almost no glue would> seal the crack that had developed. I checked the price of a Yanmar> replacement and was outraged to discover it was $76. (I don’t know> why this surprised me so much; I had to pay $175 for a warning buzzer> for the Yanmar panel.) I simply refused to pay that and went looking> on eBay for an automotive tank that seemed about the right size. > Tanks for cars run from $10 to about $25 and there is no magic in the> shape, other than fitting in the alloted space. I ordered what seemed> a reasonable replacement for $20 and when it arrived you can imagine> my surprise to discover that it was an exact, drop in replacement. I> didn’t even need to change the mounting bracket. The seller is still> advertising them on eBay, though without mentioning that it fits the> 2GM20F engine. I just wanted to share this beat-the-Yanmar-system> link with the group: > http://cgi.ebay.com/ebaymotors/Yanmar-3JH-4JH-Coolant-Recovery-Overflow-Tank-Auto-Too_W0QQitemZ320085380407QQihZ011QQcategoryZ124104QQrdZ1QQcmdZViewItem> > Al Lorman> F30 Ab Initio>
Anent the Yanmar coolant,when I spoke to a Yanmar service rep,a comment was made regarding coolant types,and a diesel specific coolant was recommended… It has something to do with vibration,cavitation,and other esoterica. I got Caterpillar coolant,already premixed 50/50 with demineralized water. Cat dealers are all over,and being generally non-marine,are not crazy on prices. 2 gals were less than $20
Sent: Monday, February 26, 2007 11:34 AM
Subject: RE: [freedomyachts2003] Re: Yanmar coolant expansion tank
Michel:
Al
Oh okay, that’s a bit different setup than I thought. As long as you
have a pressure cap somewhere to protect the hoses against over
pressure.
<ajlorman@…> wrote:
Michel:
engine.
Al
michel.capel
Al,
mailto:freedomyachts2003%40yahoogroups.com , “ajlorman”
<ajlorman@>
would
Yanmar
know
buzzer
looking
in
seemed
imagine
replacement.
I
still
Overflow-Tank-Auto-
m
Al Lorman
F30 Ab Initio
