Hi everyone.I need to have info on a stuffing box for my Yanmar 2GM20F for my 30F.I am trying to get the boat to my slip, but had to turn around and take it back to the boat yard, where I have been having upgrades and repairs.Water filled the pan below the engine, and it overflowed all over the sole.US TOW man told us, that part is no longer avail for F30 1987.Is there anyone out there that can help a first time novice?Thank you,LolaLdd
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
Posted by Al Lorman (ajl@…>)
Lola:
There
was a recent discussion on the Syntron shaft seal and one possible replacement
on this list; search the archives. Bottom line: except for one possibility,
nothing else fits. Also, are you sure that it is not just the rubber hose
that’s gone that’s gone? That’s nothing special.
Al
Lorman
Behalf Of Lola Jackson
Sent: Sunday, March 02, 2008 5:09 PM
Subject: [FreedomOwnersGroup] yanmar stuffing box F30
Hi everyone.
for my 30F.
Thank you,
LolaLdd
Second on checking for the real source of water leaks. The original seals are real tough but so often abused with grease (which they were not built to use) and lack of water cooling, and sometimes running out of alignment for long periods. I have a long message on this forum about resuscitation the Syntron. We’ll stay tuned for help if we can.FargoEx F30 #12A
Posted by Bill Williams (escbill@…>)
Check with PYI for one of their dripless shaft packings and never worry about it leaking again.
They
don’t fit in a Freedom 30.
Behalf Of Bill Williams
Sent: Sunday, March 02, 2008 7:02 PM
Subject: Re: [FreedomOwnersGroup] yanmar stuffing box F30
Check
leaking again.
Unfortunately PSS will not fit. Here is
what I wrote about the F30 Syntron and on the website there are pics of how I
replaced my Syntron with a Lasdrop.
Syntron shaft seal usually has a straight
away rubber tube but again I have only limited knowledge speaking with the new
company and talking to others. As I stated in an early thread the Syntron
company was purchased by Garlock Klozure in Palmyra, NY.
The information on Syntron (Freedom 30):
Part # for a full unit RP-32 S/H
(stainless steel) or B/H (bronze) 1” shaft 2” stern tube
Repair or maintenance kit DIR-32
S/H (stainless steel) or B/H (bronze) 1” shaft 2” stern tube.
The maintenance kit is $499.07. The whole unit unfortunately must
cost a fortune! The front plate with the fours screws is $133.57. A
brand new new must be close to $700 if the maintenance kit is $500.
The contact is:
Joe Staetmueller 800-224-4590 great guy
really helpful.
Distributors:
Motion Industries
Applied Industries Technology
There are other ones if space is not a
issue such as PSS and if space is any issue then Lasdrop Dry-Seal is workable
if a simple medication is made to the length of the cutlass bearing. I am
currently using the Lasdrop in place of the Syntron but I have no experience or
history since it was only replaced this winter on the hard but at $129 it’s
a cheap experiment. www.lasdrop.com dry-seal.
Bob
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Bill Williams
PM
To:
One more note I have a shaft saver which
is about 1 inch in width so the modification for the Lasdrop if you do not have
a shaft saver is even less maybe only an inch needs to be removed. See the
pictures on the forum.
Bob
[mailto:rweeks6508@…]
Sent: Monday, March 03, 2008 7:02
AM
To:
‘FreedomOwnersGroup@yahoogroups.com’
is what I wrote about the F30 Syntron and on the website there are pics of how
I replaced my Syntron with a Lasdrop.
The maintenance kit is $499.07. The whole unit unfortunately must cost
The contact is:
really helpful.
Distributors:
Motion Industries
it’s a cheap experiment. www.lasdrop.com
dry-seal.
Bob
PM
To:
Seems the boatyard wants to modify something off their shelf. What do you think of that? I am sending the sight you mention…Lasdrop I appreciate all the comments and help.LolaBob Weeks <rweeks6508@…> wrote: One more note I have a shaft saver which is about 1 inch in width so the modification for the Lasdrop if you do not have a shaft saver is even less maybe only an
inch needs to be removed. See the pictures on the forum. Bob From: Bob Weeks [mailto:rweeks6508@verizon.net] Sent: Monday, March 03, 2008 7:02 AM To: ‘FreedomOwnersGroup@yahoogroups.com’ Subject: RE: [FreedomOwnersGroup] yanmar stuffing box F30 Unfortunately PSS will not fit. Here is what I wrote about the F30 Syntron and on the website there are pics of how I replaced my Syntron with a Lasdrop. Syntron shaft seal usually has a straight away rubber tube but again I have only limited knowledge speaking with the new company and talking to others. As I stated in an early thread the Syntron company was purchased by Garlock Klozure in Palmyra, NY. The information on Syntron (Freedom 30): Part # for a full unit RP-32 S/H (stainless steel) or B/H (bronze) 1” shaft 2” stern tube Repair or maintenance kit DIR-32 S/H (stainless steel) or B/H (bronze) 1” shaft 2” stern tube. The maintenance kit is $499.07. The whole unit unfortunately must cost a fortune! The front plate with the fours screws is $133.57. A brand new new must be close to $700 if the maintenance kit is $500. The contact is: Joe Staetmueller 800-224-4590 great guy really helpful. Distributors: Motion Industries Applied Industries Technology There are other ones if space is not a issue such as PSS and if space is any issue then Lasdrop Dry-Seal is workable if a simple medication is made to the length of the cutlass bearing. I am currently using the Lasdrop in place of the Syntron but I have no experience or history since it was only replaced this winter on the hard but at $129 it’s a cheap experiment. www.lasdrop.com dry-seal. Bob From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Bill Williams Sent: Sunday, March 02, 2008 7:02 PM To: FreedomOwnersGroup@yahoogroups.com Subject: Re: [FreedomOwnersGroup] yanmar stuffing box F30 Check with PYI for one of their dripless shaft packings and never worry about it leaking again.
Never miss a thing. Make Yahoo your homepage.
Bob tell me how to see the pictures on Forum…paste in the site please…I’m new at this. Thank you.LolaBob Weeks <rweeks6508@…> wrote: One more note I have a shaft saver which is about 1 inch in width so the modification for the Lasdrop if you do not have a shaft saver is even less maybe only an inch needs to be removed. See the pictures on the
Posted by seychellois_lib (mcunningham@…>)
As far as I can tell the syntron shaft seal is alive and well and
being manufactured by FMC technologies:
http://www.fmctechnologies.com/upload/shaftseals.pdf
The PDF provides a pretty good engineering dwg of the seal so the
curious can see the guts.
Although I believe these units are manufactured one off. I’ve always
thought that this seal, properly installed and cooled, was probably
bullet proof, they are used in some pretty tough industrial environments.
Mike
— In FreedomOwnersGroup@yahoogroups.com, “Bob Weeks”
Syntron
Lasdrop.Syntron shaft seal usually has a straight away rubber tube but again
I have
others.
Garlock
Klozure in Palmyra, NY. The information on Syntron (Freedom 30):Part # for a full unit RP-32 S/H (stainless steel) or B/H (bronze)
1" shaft
2" stern tubeRepair or maintenance kit DIR-32 S/H (stainless steel) or B/H
(bronze) 1"
shaft 2" stern tube. The maintenance kit is $499.07. The whole unit
screws is
kit is
$500.The contact is:
Distributors:
Motion Industries
space is any
made to
was only
www.lasdrop.com http://www.lasdrop.com/ dry-seal.Bob
Subject: Re: [FreedomOwnersGroup] yanmar stuffing box F30Check with PYI for one of their dripless shaft packings and never worry
Posted by Bob (rweeks6508@…>)
Not true FMS sold the business to Garlock. See the threads on the forum for the
contact name etc at Garlock.
Bob
Date: 2008/03/09 Sun PM 07:05:59 CDT
Subject: [FreedomOwnersGroup] Re: yanmar stuffing box F30
Mike
Syntron
I have
others.
Garlock
1" shaft
(bronze) 1"
screws is
kit is
Distributors:
Motion Industries
space is any
made to
was only
