how do I fill the transmission on my yanmar 65 hp engine
A funnel?
I have had good luck with a small little red manual pumps you can get at Harbor Freight or the hardware store. Seem to work for diesel, gasoline, oil, and certainly ATF.
but where is the fill tube
What transmission do you have? I have a Kanzaki (sp?) and you fill it via the transmission dip-stick hole.
done and done
