Posted by wacormack (wacormack@…>)
A peculiar problem has surfaced with my 3gm30f and the batteries on my F36.
I have two banks. House is two 100AH gel cells and starting is one 70AH
flooded maintenance free. I have been using the house bank for starting as
well as house use and keeping the starting battery in reserve. Recently I
have been unable to start with the house bank.
To see what was going on I used a digital multi-meter connected to the panel
ground and to the amp-meter post on the panel. The house bank showed 12.33V
and stating showed 12.5. Using long wires to be able to read the meter from
the cockpit I got the following results when trying to start:
From the starting battery when I turned on the key the warning buzzer
sounded and when the starter button was pushed the engine cranked. Voltage
dropped maybe .1 volt upon turning on the key and dropped to 11.8 during
cranking. -
From the house bank there was no voltage drop (when key was turned on or
when start button pressed), no warning buzzer and no cranking.
All the house loads work fine from either bank - VHF, autopilot, gps, lights
and do register slight voltage drops when turned on.
I replaced the battery selector switch with no change in the above results.
Since the house bank was a little low I then took a motor cruise for an hour
and a half until the house bank’s voltage had risen to 14.4 as recommended
by the battery manufacturer. Still no change in the above results.
Anyone have an suggestions?
Bill
William A. Cormack, CPA
Principal and Chief Financial Officer
Whelan Associates, LLC, a Corporate Real Estate Service firm
500 Faunce Conrer Road, Building 100
North Dartmouth, MA 02747
Voice: 508-984-4100, Fax: 508-984-4101, Cell 508-254-5828
MailTo:wacormack@…
