Michel:
In the US, Formica and other similar products are actually a high pressure laminate made of multiple lawyers of paper impregnated with resin and color on the top. While not advertised as waterproof, I believe it is reasonably so. It is typically no thicker than 1/16th of an inch, and is actually available in 1/32 of an inch as well. What you are describing sounds more like a laminate covered building panel.
I have had the headliner delamination problem as well, and while I have made a temporary fix by regluing the plastic after scraping off the foam, I have been researching alternatives. There are a variety of solid plastic materials available in sheets which would easily take the required curve. This summer, I am experimenting in one corner of the main cabin with a piece of beaded plywood painted white, which the is the typical Herreshoff look in older US boats. If I go that route, I would coat both sides with epoxy before painting.
Al
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of michel.capelSent: Thursday, July 20, 2006 10:35 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Headliner
Thanks Chuck, for your suggestion. What’s on the back of the Formica? Here in the country we only have formica with course or very fine (dark brown) chipboard or MDF on the back, and that’s not very resistant to moist. But maybe there’s a treatment to make is impermeable to moist? Perhaps I could rol on a layer of epoxy on the back of the formica sheets. Any thoughts on this subject are welcome.michel— In freedomyachts2003@yahoogroups.com, Chuck Bates <cgb323@…> wrote:>> You might use Formica. I tried it in my forward cabin about 8 years> ago and have had no prblems at all with it.> > Chuck > > — “michel.capel” <michel.capel@…> wrote:> > > I have the same problem on my current Freedom and the previous one. > > This foam backed vinyl stuff is good for 15 years, after that its > > gone. The wood under my headliners is also rotted away on many place > > and full of mildew in most other places. This boat has lived on the > > Gulf coast for 15 years, so there ye go. > > > > I’m going to replace all my headliners with a solid plate material > > like foamed PVC or PE. I don’t want wood or foam anymore. > > > > If someone has a good idea about which sheet materials are good to > > use (what do they use in trailers and mobile homes as wall and > > ceiling material?) then please let me know, because I haven’t foud > > the most suitable material yet.> > > > Michel> > > > > > — In freedomyachts2003@yahoogroups.com, “Larry Strouse” > > <captainl@> wrote:> > >> > > I had same problem with 1994 F35. Took headliner loose in > > sections ,> > > primarily from transverse batten to transverse batten or > > bulkhead. Removed> > > all of foam backing by sanding and scraping with putty knife.> > > > > > Replaced with a special 3M product for vinyl. Painted it on with > > a paint> > > brush and made sure to cover every little inch. Started at batten > > with a> > > wallpaper roller getting all the air bubbles and voids out as the > > headliner> > > stretched toward the bulkhead. Had all adjacent vinyl covered > > pads around> > > edge down as well. after completion of rolling re-installed pads > > and> > > battens around edge.> > > > > > Capt. Larry E. Strouse> > > 72 Forest Green Drive> > > Mandeville, LA 70448> > > > > > 985 674 1672 Home> > > 504 835 8505 Office> > > 504 382 6078 Cell> > > > > > -----Original Message-----> > > From: freedomyachts2003@yahoogroups.com> > > [mailto:freedomyachts2003@yahoogroups.com]On Behalf Of mgkatz@> > > Sent: Wednesday, July 19, 2006 6:28 PM> > > To: freedomyachts2003@yahoogroups.com> > > Subject: [freedomyachts2003] Headliner> > > > > > > > > > > > Folks–> > > I am 1300 miles from home, cruising my F-38 this summer, and > > only access> > > to computer is a library computer. I came to my boat and found > > that the> > > vinyl headliner had separated from the foam backing on ceiling of > > cabin top> > > in several places, and pulled free from the teak battens across > > ceiling.> > > (Humidity from storage down south, not doubt.)> > > I know this has been discussed before, and I have saved the > > posts…but> > > unfortunately I cannot access them from here. Could I impose on > > someone to> > > summarize the possible “fixes” as I look into this?> > > Thanks,> > > Michael Katz> > > Freedom 38> > > “Acquittal”> > >> > > > > > > > > > > > > > > __________________________________________________> Do You Yahoo!?> Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com>
